Identify service index out of bounds
805
12-06-2010 11:31 PM
MatthewPilgrim
New Contributor III
If I call identify with id != index and max id > layer count then I get:
Server Error - Index was outside the bounds of the array
A full explanation is given from post 15 on this thread:
http://forums.arcgis.com/threads/2474-Identify-Task-issues?p=58102&viewfull=1#post58102
Can anyone confirm this as an issue and suggest a way forward without me telling the Map admin to change his maps?
Thanks, Matthew
RaviNarayanan
It sounds like a bug in handling the layerid correctly for the last layer if one or more layers in the map has broken link to the data.  I don't see any workaround other than fixing the broken layer or removing this invalid layer.
here is the bug for this issue: NIM063468
MatthewPilgrim
New Contributor III
Ravi,
Thanks for the response, I tried searching http://search.esri.com for that bug number but with no luck!
Matt
RaviNarayanan
