I would like to access mao services for example this one: http://earthobs1.arcgis.com/arcgis/rest/services/Live_Stream_Gauges/MapServer/ , if I type the url in browser, it redirects me to the arcgis online login, then I can access the map server. But if I want to access the map server using python code with the REST API, how do I get the token?
I also noticed that there are many ways to get the token, like using 'Oauth2.0 token' or 'generateToken'. I just don't know what I should use and what exactly is the url I need to use to get the token in this case.
There is a link to some code in this blog article that gets a token: Using Python to push updates to a hosted feature service from an external source | ArcGIS Blog. Here are the basic steps:
import urllib import urllib2 import json # Credentials and feature service information username = '<username>' password = '<password>' URL = "<the services url you want to connect to>" # obtain a token referer = "http://www.arcgis.com/" query_dict = { 'username': username, 'password': password, 'referer': referer } query_string = urllib.urlencode(query_dict) url = "https://www.arcgis.com/sharing/rest/generateToken" token = json.loads(urllib.urlopen(url + "?f=json", query_string).read()) if "token" not in token: print(token['error']) sys.exit(1) query_dict = { "f": "json", "token": token['token'] } # query your services url jsonResponse = urllib.urlopen(URL, urllib.urlencode(query_dict))
thanks, I haven't tried your approach yet, but I figured that I can create an application in my developer account and use the app id and secret to get token for the rest api
How to enable token for a particular map service?
