I have been creating a desktop application using Rest API.
I have ArcGIS account credentials on which I have posted some maps and layers. In my application, when I sign in to ArcGIS using my ArcGIS credentials, I need to know the hostname where my maps/layers are published. How can I get that. For one of my ArcGIS account the host name is like
https://services.arcgis.com/.........
and for another account it is like
https://services2.arcgis.com/.........
So, is there a way to figure out what is the hostname where my maps/layers are getting published?
I can definitely see the complete url of my maps/layers when I login to http://arcgis.com portal in browser and see "My Contents" which lists all my maps/layers and all that sort of stuff.
Thanks and appreciate any help in advance
After you login, and generates your token you can make the following query to see the url of your content.
http://www.arcgis.com/sharing/content/users/<username>?f=json&token=<generatedToken>
This will return you the json that contains the url of your published services.
