geometry parameter is invalid for QUERY but ok for BUFFER?!
3595
09-28-2010 12:42 PM
WillBranch
I am building a C# library wrapper for REST services (GeometryServer/buffer...).  Using this library I can buffer points, lines and polygons and get valid json responses.  I have gotten it to where I can pass in properly formatted geometries in json via POST.
However.  When it comes to passing in non-simple geometries to the QUERY service I keep getting a "geometry parameter is invalid" response...
Here is a geometry being passed into my server to be buffered, and it works.
http://216.237.216.18/ArcGIS/rest/services/Geometry/GeometryServer/buffer?...
Here is the same geometry being passed into the same server to query a parcel layer, and it does not work:
http://216.237.216.18/ArcGIS/rest/services/leesburg/MapServer/3/query?...
I also have the same problems on a ver 10 server.
Any ideas on what is wrong?
WillBranch
No ideas on what could be the problem?
Thanks again
RahulRavikumar
The Geometry service's buffer operation, takes in an array of geometries. Refer to the REST API documentation at http://help.arcgis.com/EN/arcgisserver/10.0/apis/rest/buffer.html for more information.
The Map Service query operation takes in a geometry object (as you can only specify one filter geometry at a time) and NOT an array of geometries (used for the Geometry service's buffer operation). For information on the Map Server's query operation look at http://help.arcgis.com/EN/arcgisserver/10.0/apis/rest/query.html for more information.
You should be able to use the Silverlight API, which has C# bindings for ArcGIS server's REST API, as much of this work has already been done for you. Its got a very rich client API, that you can use.
WillBranch
Rahul: Thanks very much!
