fill symbol?
1088
05-19-2011 10:18 AM
LisaT
Hi, I am new to the javascript REST API and am having issues with applying a fill symbol to polygons in a resultset.  I am using myMapService.find() to pull a resultset.  From there, I can loop through the geometries and apply a fill/stroke using google.maps.polygon:
var polygon = new google.maps.Polygon({
              paths: Lines,
              strokeColor: colorStroke,
              strokeOpacity: 1,
              strokeWeight: 2,
              fillColor: colorFill,
              fillOpacity: 1,
              clickable: false
However, I need to apply a diagonal stroke style to my fill instead of ONE color.  I see in the documentation (http://sampleserver3.arcgisonline.com/ArcGIS/SDK/REST/index.html) that there are symbol and renderer objects...but how to apply them??  I see a lot of examples utilizing dojo that access "map.graphics" or "feature.setSymbol", but these do not seem to be available with REST.  I have created my fill symbol:
   var fillSymb ={
        "type": "esriSFS",
        "style": "esriSFSBackwardDiagonal",
        "color": "#ADEFAB",
        "outline": {
            "type": "esriSLS",
            "style": "esriSLSSolid",
            "color": [110,110,110,255],
            "width": 1
How do I apply it to my result set??
Any comments/ideas would be MUCH appreciated!  Thank you!
LisaT
              paths: Lines,
              strokeOpacity: 1,
              strokeWeight: 2,
              fillOpacity: 1,
              clickable: false
   var fillSymb ={
        "type": "esriSFS",
        "color": "#ADEFAB",
        "outline": {
            "type": "esriSLS",
            "width": 1
It has been a month with no replies...anyone have an idea as to why the fillsymbol object even exists in this library??  In what capacity would it even be used??  I have a heavy ArcObjects background and am having real problems with the limitations on the REST API...and now I'm finding that of the few objects available, many are not even usable!?  Please help if I am missing something!
derekswingley1
Since you're using the extender for Google Maps, you're limited by the capabilities of v2 of the Google Maps API. As far as I know, there is not a way to have use a diagonal fill symbol. The only way I know to accomplish this would be to move to the full ArcGIS API for JavaScript.
LisaT
OK, so does anyone know how/why to use the "RendererObject" in the REST API?  (http://sampleserver3.arcgisonline.com/ArcGIS/SDK/REST/index.html) If not used as I am wanting to use it, why is it there?
I am trying to build a case for using something different.  However, there is red tape in my company...
