Extent for feature layers data download
859
09-16-2019 12:44 PM
DevendraKhatri
I have rest APIs that I use to generate geodatabase/ create replica, also I use query for filters for some queries. What I am looking for, is the extent option that I can pass in request. Does ESRI has support for this? Right now I am fetching data for whole globe which might lead to larger data set in future. I need to restrict download of geometries that comes inside specified extent.
EarlMedina
Hi Devendra,
Can you clarify which REST API operation(s) you are using? It seems like Create Replica—ArcGIS REST API: Services Directory | ArcGIS for Developers is at least one of them?
If so, Create Replica has a 'geometry' parameter you may use for the purpose.
-Earl
DevendraKhatri
 I am not using createRepica API. I am using "geometry" parameter of this API
Query (Feature Service)—ArcGIS REST API: Services Directory | ArcGIS for Developers
but the response I am getting is not returning the features restricting to the extent I provide in the "geometry" parameter. It is returning the geometry that I pass instead
I need the geometries that are under the extent I pass.
EarlMedina
Okay, so you're trying to do something like this?
https://sampleserver6.arcgisonline.com/arcgis/rest/services/Earthquakes_Since1970/FeatureServer/0/qu...
Where in this case the source layer is: Layer: Earthquakes1970 (ID: 0)
and we are returning points that fall more or less within the United States.
-Earl
