Export Web Map scales symbols
772
06-28-2017 01:38 AM
MathieuVillemont
I'm exporting a web map containing some graphics using PNG symbols.
However the size of the symbols in the PDF varies from the web map.
Strange things is that the symbols size also changes if I choose a different scale (cf. 5000.png and 25000.png).
Each graphics is sent with this JSON format :
     "geometry": {
          "x": 152234.89785321,
          "y": 6216854.2413964,
          "spatialReference": {
               "wkid": 102100
     "attributes": {},
     "symbol": {
          "angle": 0,
          "xoffset": 0,
          "yoffset": 0,
          "type": "esriPMS",
          "url": "point_ref.png",
          "width": 12,
          "height": 12
MathieuVillemont
Hi Shan,
I actually did not want to modify my JSON manually so I ended up modifying my data block properties in the MXD : General > Reference scale: <None> and it works!
shan_sarkar
Mathieu,
Have you tried using the following?
template.exportOptions = {
width: 500,
height: 400,
dpi: 96
template.format = "PDF";
template.layout = "MAP_ONLY";
template.preserveScale = true;
I hope this helps!
~Shan
~Shan
MathieuVillemont
Hi Shan,
