Cannot view deployed SOE directly
1898
12-26-2012 09:26 AM
XintaoLiu
Occasional Contributor II
After I deployed a SOE (see attachment), I cannot view the SOE directly in the ArcGIS Services directory. Why?
RichardWatson
After you deploy an SOE then you create a map service and explicitly enable the SOE.
Show us the screen shots of the map service you created with the SOE enabled.
An SOE is like an addition to a map service.
RichardWatson
XintaoLiu
Thanks! I thought a SOE would be the same as a Map Service that can be viewed in ArcGIS Services directory. Got it, thank you.
