10.1 SP1 returnDistinctValues not working with geometry parameter
3682
08-09-2013 07:20 AM
JiriKozel
I've probably found a bug in ArcGIS REST API 10.1 SP1.
If I use the parameter returnDistinctValues=true together with geometry=<envelope>, the server returns all values sorted by alphabet (in my case, values are strings).
Example:
.../arcgis/rest/services/sp/MapServer/1/query?where=1%3D1&outFields=kodPodlazi&returnGeometry=false&returnDistinctValues=true&f=pjson&geometry=-599170.85274263%2C-1160312.4059257%2C-598415.75836763%2C-1159973.8636132&geometryType=esriGeometryEnvelope&spatialRel=esriSpatialRelIntersects
Output:
   "attributes": {
    "kodPodlazi": "M03"
   "attributes": {
    "kodPodlazi": "N01"
   "attributes": {
    "kodPodlazi": "N01"
If I use the parameter returnDistinctValues=true without geometry, everything works as expected (only distinct values are returned).
Example:
Can you please confirm that this is a bug?
JohnGravois
sorry for the extremely late reply, but i just came across this forum thread and can't reproduce the behavior you describe in 10.21
http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/2/query?where=STATE_NAME...
hopefully that means the problem has been solved.
AndrewBrown1
Occasional Contributor II
Can you confirm this is a bug at 10.1 QIP SP1?
We cannot upgrade to 10.2 at this point due to security issues. I wish it were that easy.
