Currently you can change the style, labels, and visibility range at the hosted feature layer definition. It would be nice to define pop-ups like you would at the web map level at the layer definition. This would allow for consumption of feature layers with customized pop-ups using the Javascript API FeatureLayer class instead of consuming a WebMap which includes the layers with customized pop-ups.
Hi @Anonymous User,
Isn’t this possible from ‘Visualization’ tab under ‘Item Details’ on hosted feature layers ?
There are 2 ways to configure popups. One is in map viewer.
https://support.esri.com/en/technical-article/000019514
Thanks!
