Please see my question at Esri Community.
I have been advised by an expert to submit this issue in "Ideas", so I'm doing it -
I suggest to let web application based on esri REST API "live" by enabling them import zipped shapefiles with more than 4,000 records, using ArcGIS REST API - Generate.
This could be done by raising ArcGIS REST API - Generate arbitrary limit of max 4,000 records,
and so enabling it to create shapefile(s) from zip that contains a total records count greater than 4,000.
Once upon a time, this arbitrary limit was set to 1,000. Currently it has been raised to 4,000.
As technology moves forward and files get bigger and more complicated, I suggest to increase this limit.
With appreciation,
Michael
