Not loggin in an Enterprise account to QuickCapture website.
285
6
01-18-2021 07:08 AM
DanielMurillo
New Contributor III
Hello everyone:
I am having trouble logging an Enterprise 10.8.1 account to Quick Capture website: https://www.arcgis.com/apps/quickcapture/
When I pick the option before the login to enter using ArcGIS Enterprise, it makes me place the URL of the portal, right after I paste the URL it says that -----'Unable to retrieve information about this portal. Either the URL is incorrect or portal resources are not accessible.'-----, but it gives you the option to 'Continue anyway' and it launches the login page to portal, but if I put the portal Administrator user and password and hit login, the request starts cycling itself, actually if I open Fiddler it shows no answer from the request to login.
Any idea how I can login correctly?
I have a technical case on salesforce, but with no answer on what can be happening here.
@IsmaelChivite
DanielMurillo
New Contributor III
Hello @JohnathanHasthorpe , we finally resolved it, it ended up being the cors policy on the tomcat server. We added the exceptions and it went right in.
Thanks, either way!
Greetings!
JohnathanHasthorpe
Hi Daniel - It sounds like you are signing into an IWA portal? If so, is the admin account a Windows account?
DanielMurillo
New Contributor III
Hello @JohnathanHasthorpe : Actually, they are using ArcGIS portal accounts and using the built in identity store. If I am not mistaken their portal is running on Linux servers.
The escalated case owner told me to tell the customer to check on the connections, however customer checked, and everything looks fine, the communication seems to flow in and out as it should.
But I don't know if you had seen such a particular scenario?
Any thoughts would be appreciated.
Greetings;
-Daniel
JohnathanHasthorpe
The designer is trying to make a request for the portal self information (https://developers.arcgis.com/rest/users-groups-and-items/portal-self.htm). If it does not get this back, it assumes that it is an IWA portal and allows the user to try to sign in anyway.
Can you check that the portal self url is accessible by testing in a browser?
DanielMurillo
New Contributor III
Hello @JohnathanHasthorpe : I went and tried entered my clients portalurl/webadaptor/self and it is showing 404, also if i write portalurl/self.
JohnathanHasthorpe
Hi Daniel - can you email QuickCapture@esri.com
We'll try to troubleshoot this with you.
Thanks
John
DanielMurillo
New Contributor III
Thanks, either way!
Greetings!
