With most apps, including Field Maps and Survey123, the Tab and Enter keyboard buttons have a consistent behavior on a sign in screen. This behavior is most noticeable when a bluetooth keyboard is being used with a mobile device (iPad in my case).
When finished typing in a username, Tab usually advances the cursor to the next (password) field. In QuickCapture, it literally inserts a tab into the username field. Instead, the password field must be tapped on screen to move the cursor there.
When finished typing in a password, Enter usually submits the credentials for evaluation. In QuickCapture, pressing the Enter key does nothing. The Sign In button must be tapped on the screen to submit the credentials.
Hi Todd,
What platform are you using and are you sigining in to ArcGIS Online or ArcGIS Enterprise?
Thanks
John
iPad, all iOS versions observed since about 13+ (now on 15.4.1)
Logging into ArcGIS Enterprise 10.9.1 (also observed previously on 10.8.1)
Hi Todd, are you IWA or PKI to sign in?
We use Integrated Windows Authentication
Planned for 1.15 (September 2022)
Implemented in 1.15
