We have put together a concept for snow removal where we use QuickCapture to register work performed in the field. To show / share position with other resources and to headquarters, we use ArcGIS Tracker. The user then has to start 2 applications and it can be a bit difficult. What if the traker capacity was included in QuickCapture so that the user only has to deal with one application? Of tracker information, we need the last known position, direction and speed. Update intervals can e.g. be every 30 seconds.
