Allow Authors to configure QC pop-up visible in Mobile Application
452
05-05-2022 02:14 PM
Status: Under Consideration
Labels (2)
MeganEngel
Occasional Contributor II
Please add the functionality in the designer for the Authors to edit the pop-ups that are displayed in mobile application prior to syncing.  Currently the project user input and preview of the button shows up in those pop-ups and all icons are aqua color.
Allowing the author to update both the pop-up and icon color would be great.  One idea for the icon color would be to match it to the button the user would select in the field.
Here is a use case: In a given QC application, users are required to type in their name, and a project name (as a project user input).  Why they are collecting they may need to pop over to the map to review the locations of the data points, they can see their project name, the button they selected, and how long ago the data point was collected.  Sometimes that isn't enough information, particularly if folks are writing notes with those points.  Which while reviewing the data prior to syncing is important, in case there were points they took they want to delete and do not know which to delete because they cannot see the notes.
By allowing the author to update what is visible in that pop-up (while maintaining the minimized look) would be beneficial. There is defiantly space in that pop-up to add in an attribute field
1 Comment
JohnathanHasthorpe
