ArcGIS QuickCapture Blog
Other Boards in This Place
Latest Activity
(54 Posts)
BrandyPerkins
Learn how to streamline field data collection using the integrated Arcade editor in the QuickCapture web designer. You can configure Arcade expressions from the Data tab for each capture field in the project.
Read more...
more
3 1 1,069
BrandyPerkins
Try out the integrated Arcade editor in the QuickCapture web designer to write Arcade expressions that populate fields for collected data. This workflow is applicable to data collected online and offline.
Read more...
more
2 0 909
IsmaelChivite
Esri Notable Contributor
Arcade, more user inputs, oriented imagery layer support and more in this update! Read on to learn more...
Read more...
more
6 3 1,202
GlenShepherd
In the event that records to fail to send from your mobile device, we need a method for recovering and exporting them, so that they can be appended to the feature layer.
These are the steps for an iOS device
  • Install iTunes on your laptop
  • Connect the device to your laptop
  • Open iTunes, click on your device, and navigate to: File Sharing > Apps: QuickCapture > select the “ArcGIS” folder > 'Save' it to a local directory
  • Within that folder, locate a file with a ".qcr" (QuickCapture Recovery) extension.
  • Rename this file with a ".zip" extension, and then extract the data locally.
  • Within the unzipped folder, find the sqlite database containing the orphaned records.
For an Android device, the process is the same.  However we can use File Explorer instead of iTunes.
more
5 1 295
IsmaelChivite
Join us on November 9. Learn about what's coming, test the Beta software and provide feedback to the QuickCapture team!
Read more...
more
4 0 557
IsmaelChivite
Did you miss our Get Started Webinar on May 24? No worries! Here is the recording.
Read more...
more
4 0 1,101
IsmaelChivite
A new update to ArcGIS QuickCapture is now available! It is time to download the latest update from the app store. Take advantage of new features, including:
  • Video Recording
  • Enhanced App Linking
  • A better icon gallery
  • Other enhancements and fixes
Read more...
more
0 3 514
IsmaelChivite
One more update before the end of 2022! The QuickCapture mobile app has been updated in the Apple, Google Play and Microsoft app stores. The build number is now 1.16.292.  As usual, all your existing projects will continue to work with this new release, but there is a lot more to this release than that...
Read more...
more
1 4 669
IsmaelChivite
Learn what's coming in December 2022
Read more...
more
4 12 1,538
IsmaelChivite
The recording of our DirectionsMag ArcGIS QuickCapture webinar today is now ready along with answers to many of the questions we could not answer during the event. All the info is here. Enjoy!
Read more...
more
1 0 1,201
102 Subscribers
