Today you will find a new ArcGIS QuickCapture update in the Apple and Google Play stores. We also have refreshed it's Windows flavor, as well as QuickCapture designer. This is version 1.1, and here are some highlights:
If you are not familiar with ArcGIS QuickCapture, check our version 1.0 release announcement.
The next time you open the QuickCapture mobile app, it will welcome you in your own language. It is now available in over 30 languages, including 'right to left' languages like Arabic and Hebrew.
Text to speech functionality also works in most languages, although it will automatically be disabled if the operating system in your device does not support text to speech in the active language.
If you plan to deploy ArcGIS QuickCapture against your own instance of ArcGIS Enterprise, this will make a difference: When setting up a connection to ArcGIS Enterprise, you no longer need to manually type the URL: A handy barcode scanner has been added to streamline this workflow.
To take advantage of this feature, you will need to create first a QR barcode representing the URL of your ArcGIS Enterprise portal. Here is what an ArcGIS Enterprise URL looks like:
https://myportal.acme.com/webadaptorname
Note that I left the /home out of it. Keep /home for your browser. You do not need to include that for QuickCapture:
https://myportal.acme.com/webadaptorname (Correct)
https://myportal.acme.com/webadaptorname/home (Incorrect)
There are many utilities out there to help you create a QR code from your ArcGIS Enterprise URL. I like QR Code Generator, but there are many others.
Once you have the QR code, you can include it in an e-mail with step by step instructions, print it on paper, etc.
With this update, you no longer need to manually stop -one by one- all active buttons before you can close your project in the mobile app. A new confirmation dialog will let you end all active captures with a single tap. A time saver for field users.
With QuickCapture designer, right from a web browser, you can create your own projects for the QuickCapture mobile app. Here is what is new in this update:
The next update to ArcGIS QuickCapture is planned to be made available in September. Beta builds available through the ArcGIS QuickCapture Early Adopter Program.
