WPF DataGrid with ArcGIS Pro SDK Style does not allow to edit cells
1739
03-11-2019 08:31 AM
KarlHuber
New Contributor III
We use a WPF DataGrid inside a ArcGIS Pro Pane with custom styling as suggested by the ArcGIS Pro SDK Style Guide But if we declare our DataGrid like this, all cells become disabled.
<DataGrid Grid.Row="3"
          ItemsSource="{Binding Path=SelectedMember.PropertyDefinitions}"
          Style="{DynamicResource Esri_DataGrid}"
          ColumnHeaderStyle="{DynamicResource Esri_DataGridColumnHeader}"
          CellStyle="{DynamicResource Esri_DataGridCell}"
          AlternatingRowBackground="LightGray"
          CanUserAddRows="True"
          CanUserDeleteRows="True"
          AutoGenerateColumns="False">
    <DataGrid.Columns>
        <DataGridTextColumn Header="Name" Binding="{Binding Path=Name}"></DataGridTextColumn>
        <DataGridTextColumn Header="Display Name" Binding="{Binding Path=DisplayName}"></DataGridTextColumn>
        <DataGridTextColumn Header="Category" Binding="{Binding Path=Category}"></DataGridTextColumn>
        <DataGridTemplateColumn Header="Column">
            <DataGridTemplateColumn.CellTemplate>
                <DataTemplate>
                    <TextBlock Text="{Binding Column}"></TextBlock>
                </DataTemplate>
            </DataGridTemplateColumn.CellTemplate>
            <DataGridTemplateColumn.CellEditingTemplate>
                <DataTemplate>
                    <ComboBox ItemsSource="{Binding Columns}" SelectedItem="{Binding Column}"></ComboBox>
                </DataTemplate>
            </DataGridTemplateColumn.CellEditingTemplate>
        </DataGridTemplateColumn>
        <DataGridCheckBoxColumn Header="Visible" Binding="{Binding Path=IsVisible}"></DataGridCheckBoxColumn>
        <DataGridCheckBoxColumn Header="Read Only" Binding="{Binding Path=IsReadOnly}"></DataGridCheckBoxColumn>
    </DataGrid.Columns>
</DataGrid>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
There's no chance to edit a cell value by double clicking anymore. Do we miss something? If we do not set custom styles everything works like we would like to have it...
MatthewDriscoll
Try adding to the DataGrid
IsReadOnly="False"
AlexWieschmann2
New Contributor II
No, unfortunately that doesn't help and the problem still exists...
AlexWieschmann2
New Contributor II
It works, the option only needs to be set for the entire data grid, not just for a specific element
