Which DAML ID must be used for adding a button to the layer/standalone context menu like "Attribute Table" is doing?
2181
07-08-2021 03:52 AM
Jan-Tschada
We need to add a custom button to the context menu for feature layers. In the past we used esri_mapping_layerContextMenu and esri_mapping_standaloneTableContextMenu.
We define the state as insert conditions for layers and standalone tables by using:
  • <state id="esri_mapping_singleLayerSelectedCondition"/>
  • <state id="esri_mapping_singleFeatureLayerSelectedCondition"/>
  • <state id="esri_mapping_singleStandaloneTableSelectedCondition"/>
With ArcGIS Pro 2.7 and 2.8 esri_mapping_layerContextMenu seems not to work for any shapefile related layers, any help would be appropriated.
Product Manager
Developers and Location Services
Germany and Switzerland
Jan-Tschada
We finally figured it out, also we have to use singleLayerSelectedCondition instead of singleFeatureLayerSelectedCondition for enabling it.
<conditions>
    <insertCondition id="esri_mapping_single_layer_selected">
      <and>
      </and>
    </insertCondition>
    <insertCondition id="esri_mapping_single_standalonetable_selected">
      <and>
      </and>
    </insertCondition>
  </conditions>
<updateModule refID="esri_mapping">
      <menus>
        <updateMenu refID="esri_mapping_layerContextMenu">
          <insertButton refID="SDA_Pro_Module_Create_Sda_From_FeatureTable_Button" separator="false"   placeWith="esri_editing_table_openTablePaneButton" insert="after" />
        </updateMenu>
        <updateMenu refID="esri_mapping_unregisteredLayerContextMenu">
        </updateMenu>
        <updateMenu refID="esri_mapping_standaloneTableContextMenu">
          <insertButton refID="SDA_Pro_Module_Create_Sda_From_StandaloneTable_Button" separator="false" placeWith="esri_editing_table_openStandaloneTablePaneButton" insert="after" />
        </updateMenu>
        <updateMenu refID="esri_mapping_unregisteredStandaloneTableContextMenu">
        </updateMenu>
      </menus>
    </updateModule>
Using unregistered context menu did the trick. See Solved: Buttons built by ArcGIS Pro SDK cannot be added to... - Esri Community
Product Manager
Jan-Tschada
<conditions>
      <and>
      </and>
    </insertCondition>
      <and>
      </and>
    </insertCondition>
  </conditions>
      <menus>
        </updateMenu>
        </updateMenu>
        </updateMenu>
        </updateMenu>
      </menus>
    </updateModule>
Product Manager
