Where can I find a reference for pre-defiled DAML values of existing control IDs and application conditions?
4806
12-13-2015 11:58 PM
by Anonymous User
Not applicable
When I interact with existing ArcGIS Pro controls (such as button), I need to use pre-defined DAML values such as existing button control ids (ex: esri_mapping_fixedZoomInButton, esri_mapping_zoomFullButton) and application conditions (ex: esri_core_MapPane, esri_mapping_onlyFeatureLayersSelectedCondition).
Some of them are used in the following page:
ProGuide Ribbon, Tabs and Groups · Esri/arcgis-pro-sdk Wiki · GitHub
Is there any reference available that will list these pre-defined existing control IDs or application conditions?
CharlesMacleod
Hi Shohei,
To add the ids to your project use the ArcGIS Pro SDK for .NET Utilities, Pro Generate DAML IDs utility. It is shown here. After you have run it, the ids will show up in Intellisense within a csharp or vb code window.
At 1.2 we will include a complete listing of DAML ids on the  ArcGIS Pro SDK wiki
CharlesMacleod
Hi Shohei,
by Anonymous User
Not applicable
Hi Charles
Thank you for your reply.
By running the utility, I’m now able to see the all available DAML ids.
Thank you!
TedChapin
Occasional Contributor III
UmaHarano
Hi Ted, Shohei
Here is a FAQ that lists all the ways by which you can access the DAML ids.
Thanks
Uma
