Having temporary elements on a map is a nice light-weight tool for users to add meaning to what they are looking at. Often, these need to be more sophisticated than simple Map Notes:
https://community.esri.com/ideas/10410
Is it on the roadmap to allow developers access to the Pro graphics layer? Or, to an isolated graphics layer that is filled with 3rd party elements?
Jeremy,
You can use the AddOverlay method to display a graphic on a 2D map by providing a geometry and a symbol.
This method is available from either the MapView or a MapTool.
The following example displays the vertices of a selected polyline as a graphic.
protected override void OnClick()
//Run on MCT
QueuedTask.Run(() =>
//get selected polyline
var selectedFeatures = ArcGIS.Desktop.Mapping.MapView.Active.Map.GetSelection();
var insp = new ArcGIS.Desktop.Editing.Attributes.Inspector();
insp.Load(selectedFeatures.Keys.First(), selectedFeatures.Values.First());
var polyLine = insp.Shape as ArcGIS.Core.Geometry.Polyline;
//mp builder
var multiPointBuilder = new ArcGIS.Core.Geometry.MultipointBuilder();
multiPointBuilder.Add(polyLine.Points);
//add overlay
var markerSymbol = ArcGIS.Desktop.Mapping.SymbolFactory.ConstructMarker(ColorFactory.Red, 11.0, SimpleMarkerStyle.Diamond);
var ptSymbol = SymbolFactory.ConstructPointSymbol(markerSymbol);
var vertexGraphics = MapView.Active.AddOverlay(multiPointBuilder.ToGeometry(), ptSymbol.MakeSymbolReference());
//vertexGraphics.Dispose(); //to clear the overlay
}Note that this works differently from the ArcMap graphics container as the graphic is referenced by the returned IDisposable variable. This is usually managed within the lifetime of a tool.
I have added a marker symbol with this code but how to I programmatically label the symbol or create a popup with information on the map? for example, I want to label the point with "Latitude = 38.12345, Longitude = -97.65432"
Here is a screen shot of how I want the symbol and label to look.
Its not currently possible to add text as graphics. There is no ETA on when that might be available.
