'Table panes cannot be accessed from a thread other than the thread they were created on.' Opening a standalone table pane (ArcGIS Pro SDK C#)
1293
01-15-2020 01:21 PM
JohnPhillipsGeo
New Contributor III
Hello, I am experiencing an error when trying to add a standalone table to a map.
I saw some other threads and borrowed some code from them, but I keep running into this same Error:
The code successfully routes my table (from a local gdb) and adds the routed linework and the underlying standalone table to the map.  However, when I attempt to open the table in the table pane, I keep getting this error.
Any help would be much appreciated!
Thanks
John
using System;
using System.Collections.Generic;
using System.Collections.ObjectModel;
using System.Diagnostics;
using System.IO;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using ArcGIS.Core.CIM;
using ArcGIS.Core.Data;
using ArcGIS.Core.Geometry;
using ArcGIS.Desktop.Catalog;
using ArcGIS.Desktop.Core;
using ArcGIS.Desktop.Core.Geoprocessing;
using ArcGIS.Desktop.Editing;
using ArcGIS.Desktop.Extensions;
using ArcGIS.Desktop.Framework;
using ArcGIS.Desktop.Framework.Contracts;
using ArcGIS.Desktop.Framework.Dialogs;
using ArcGIS.Desktop.Framework.Threading.Tasks;
using ArcGIS.Desktop.Mapping;
namespace BulkLoadTool
internal class Tomato : Button
protected async override void OnClick()
try
var lyr = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().First(l => l.Name.Contains("TxDOT_Roadways_Edits"));
//var Datapath =
await QueuedTask.Run(() =>
var gdbPath = lyr.GetFeatureClass().GetDatastore().GetPath();
var tblName = lyr.GetTable().GetName();
string fullPath = Path.Combine(gdbPath.LocalPath, tblName);
string in_routes = fullPath; //Datapath.Result
string route_id_field = "GID";
string gPath = Path.Combine(@"C:\TxDOT\BulkLoad\AssetTables", System.IO.File.ReadAllText(@"C:\TxDOT\BulkLoad\LayerReference\configFiles\selGDB.log"));
string inTbl = Convert.ToString(Module1.Current.TblDropDown.SelectedItem);
string inTblPath = Path.Combine(gPath, inTbl);
string in_table = inTblPath;
string in_event_properties = "RDBD_GMTRY_LN_ID LINE ASSET_LN_BEGIN_DFO_MS ASSET_LN_END_DFO_MS";
string out_layer = Module1.Current.TblDropDown.SelectedItem.ToString();
var args = Geoprocessing.MakeValueArray(in_routes, route_id_field, in_table, in_event_properties, out_layer);
string toolPath = @"C:\Program Files\ArcGIS\Pro\Resources\ArcToolBox\Toolboxes\Linear Referencing Tools.tbx\MakeRouteEventLayer";
Geoprocessing.ExecuteToolAsync(toolPath, args);
string sGDB = System.IO.File.ReadAllText(@"C:\TxDOT\BulkLoad\LayerReference\configFiles\selGDB.log");
using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(gPath))))
using (Table table = geodatabase.OpenDataset<Table>(inTbl))
IStandaloneTableFactory tableFactory = StandaloneTableFactory.Instance;
var insTbl = tableFactory.CreateStandaloneTable(table, MapView.Active.Map, inTbl);
FrameworkApplication.Panes.OpenTablePane(insTbl);
//return insTbl;
catch (Exception e)
Trace.WriteLine(e.Message);
RichRuh
Than is on the right track.  The Geodatabase constructor and the call to Geodatabase.OpenDataset<Table> at the end of the snippet should also be inside a QueuedTask.Run block.  The call to OpenTablePane should not.
Try the following:
if (!ProcessingReuslt.IsFailed)
  Trace.WriteLine("Success");
  var insTbl;
  await QueuedTask.Run(()=>
        IStandAloneTableFactory tableFactory = StandaloneTableFactory.Instance;
This will open the table on the MCT (geodatabase thread) and open the table pane on a UI thread.
I hope this helps,
--Rich
by Anonymous User
Not applicable
Hi @John Phillips,
How about trying to wrap the queuetask for the require code only.
And add await for geoprocessing task, this is async thread and if there is no await , next statement shall run and end up another statement is running before finishing gp task.
Below is the sample update, try and let me know
     try
                    //var Datapath =
                    Uri gdbPath = null;
                        string tblName = "";
                    string fullPath = "";
                    var gpResult = Geoprocessing.ExecuteToolAsync(toolPath, args);
                    gpResult.Wait();//Wait for geoprocessing task to finish
                    IGPResult ProcessingResult = gpResult.Result;
                    if (!ProcessingResult.IsFailed)
                                //return insTbl;
            catch (Exception e)
JohnPhillipsGeo
New Contributor III
Hello Than,
Thank you for your response.  I tried the code that you provided and unfortunately I am still experiencing the same error.
The IGPResult is successful and the code is reaching the OpenTablePane call. Thanks for your help!
RichRuh
Try the following:
  var insTbl;
I hope this helps,
--Rich
JohnPhillipsGeo
New Contributor III
Rich, that worked!  Thank you so much for yours and Than Aung‌ 's help!
Also, thanks for explaining the difference between the MCT and UI threading here.. I remember learning about that but hadn't explicitly put it to use.  Looking forward to the Dev Summit this year to learn more
RichRuh
Glad it worked.  See you in Palm Springs!
