Retrieve user input from ProWindow dialog without global variables?
494
11-03-2022 03:21 PM
succip
I'd like to retrieve user input from a ProWindow dialog, then use that input to do a bunch of stuff in my MapView/Tables. Following this example (https://github.com/Esri/arcgis-pro-sdk-community-samples/tree/master/Framework/ProWindowMVVM), I see them using Module1 to store/retrieve global variables, is this best practice in a case where I'll be building multiple ProWindow forms? I worry it will get overwhelming quickly if I want to track 5-10 properties per window.
Is there any other way of retrieving user input from a ProWindow? The ShowDialog() method only returns a boolean.
Happy to provide more details but I wanted to keep my question as simple as possible. As of right now my code is as follows as an example:
TestButton.cs:
namespace SurreyTools
    internal class TestButton : Button
        private CreateLotWindow _createlotwindow;
        protected override void OnClick()
            if (_createlotwindow != null)
                return;
            _createlotwindow = new CreateLotWindow();
            _createlotwindow.Owner = FrameworkApplication.Current.MainWindow;
            _createlotwindow.Closed += (o, e) => { _createlotwindow = null; };
            _createlotwindow.ShowDialog();
CreateLotsWindowViewModel:
    public class CreateLotWindowViewModel: PropertyChangedBase
        private string _lotCount;
        public string LotCount
            get => _lotCount;
            set
                SetProperty(ref _lotCount, value, () => LotCount);
        public ICommand SubmitLotNumber => new RelayCommand((createLotWindow) =>
            (createLotWindow as CreateLotWindow).DialogResult = true;
            (createLotWindow as CreateLotWindow).Close();
        }, () => true);
I'd like some way to pass the lotCount property to either my button or any other use case.
GKmieliauskas
On Closed event it destroys objects. I don't use that pattern. You can use local variable like this:
            CreateLotWindow createlotwindow = new CreateLotWindow();
            if(createlotwindow.ShowDialog()== true) {
                var viewModel = createlotWindow.DataContext as CreateLotWindowViewModel;
                var count = viewModel.LotCount;
GKmieliauskas
You can use DataContext to access view model properties:
                return;
            if(_createlotwindow.ShowDialog()== true) {
                var viewModel = _createlotWindow.DataContext as CreateLotWindowViewModel;
succip
Hello, thanks for your help, but I'm getting an error. once code enters the if statement, _createlotwindow becomes null. I assume this is because I'm setting _createlotwindow.Closed to make the object null on close. It works fine if I set the DataContext before the ShowDialog(). Is there any harm in doing that?
                return;
            var viewModel = _createlotwindow.DataContext as CreateLotWindowViewModel;
            if (_createlotwindow.ShowDialog() == true)
GKmieliauskas
succip
Is there a trick to doing this in a RowCreatedEvent? I'm getting a thread issue error trying to call it. I found this answer from 2020 but I'm having trouble parsing the code in French. I've tried wrapping everything in the Current.Dispatcher.Invoke() but then my OK button is disabled (I assume because the thread is locked).
My code:
public static void OnRowCreated(RowChangedEventArgs args)
            CreateLotWindow createLotWindow = new CreateLotWindow();
            createLotWindow.Owner = FrameworkApplication.Current.MainWindow;
            var vm = createLotWindow.DataContext as CreateLotWindowViewModel;
            if (createLotWindow.ShowDialog() == true)
                string lotNo = vm.LotCount;
                QueuedTask.Run(()=> {
                     // do stuff with user input
Thanks again.
