Refresh homefolder/catalog to see newly added contents
496
6
01-31-2021 04:59 PM
PrashantKirpan
I've created ArcPro Add-in in C# and added folder under home folder and copying project related content into it.
After adding folder I'm activating Catlog pane. If my project home folder is already in open state then i can't see newly added folder. I need to manually click on folder/homefolder location and hit refresh command.
Is there any way I can programmatically refresh homefolder/folder to see updated contents?
Any help would be appreciated.
Regards,
Prashant
KirkKuykendall1
Occasional Contributor III
I guess Esri might change internal interfaces in future releases, but typically once an interface is defined it's not supposed to change (?)
This works for me:
foreach (var itm in Project.Current.Items.OfType<FolderConnectionProjectItem>())
    ((ArcGIS.Desktop.Internal.Core.IItemInternal)itm).RefreshChildren();
FredericPoliart_EsriAU
New Contributor II
Hi
You may be able to invoke esri_itemInfoRefreshButton manually,  but you would have to specify which folder.   There could also be an "invalidate" command, which would force your Catalog to refresh/reload the newly added folders.
https://github.com/Esri/arcgis-pro-sdk-community-samples/blob/master/Map-Exploration/IdentifyWindow/...
PrashantKirpan
I tried to execute below code but CanExecute returning false so unable to execute command. Also not sure how to specify folder to execute command? Could you please provide any sample?
var commandId = @"esri_itemInfoRefreshButton";
var iCommand = FrameworkApplication.GetPlugInWrapper(commandId) as ICommand;
if (iCommand != null)
  if (iCommand.CanExecute(null))
    iCommand.Execute(null);
-Prashant
New Contributor II
The following sample has similar  FrameworkApplication.GetPlugInWrapper() commands:
https://github.com/Esri/arcgis-pro-sdk-community-samples/tree/master/Framework/HookProCommands
but I agree, you would need to specify which sub-folder you are targeting (for the refresh)
PrashantKirpan
I tried to execute refresh command in same project but still CanExecute returning false value. Exit application/Bookmark are working fine.
Could you please help me out to set target for refresh command?
 protected override void OnClick()
            var commandId = FrameworkApplication.GetPlugInWrapper(@"esri_core_exitApplicationButton") as ICommand;
            if (commandId != null)
                if (commandId.CanExecute(null))
                    commandId.Execute(null);
            var commandId1 = FrameworkApplication.GetPlugInWrapper(@"esri_itemInfoRefreshButton") as ICommand;
            if (commandId1 != null)
                if (commandId1.CanExecute(null))
                    commandId1.Execute(null);  /******** Not Executing ***********/
-Prashant
KirkKuykendall1
This works for me:
PrashantKirpan
Thank you @KirkKuykendall1 , Perfectly working 👍
