Protected memory issue while modifying shapefile data
673
06-18-2020 07:56 AM
Sai_PhaneendraPoludasu2
New Contributor III
There are around 50k records in a shapefile feature class. I am using following code block to modify the features.
private async Task UpdateData(FeatureLayer layer)
            using (FeatureClass oInFC = layer.GetFeatureClass())
                var featCursor = oInFC.Search(null, false);
                EditOperation editOperation = new EditOperation();
                editOperation.Callback(context =>
                    while (featCursor.MoveNext())
                        var feat = featCursor.Current;
                        //Modify feature attributes
                        feat.Store();
                        context.Invalidate(feat);
                }, oInFC);
                try
                    var result = await editOperation.ExecuteAsync();
                    if (!result)
                        throw new Exception(editOperation.ErrorMessage);
                catch(Exception ex)
                    //Handle Exception
I see a protected memory access violation exception randomly. Any idea why this might be occurring ?
Sai
GKmieliauskas
Hi Sai,
ArcGIS Pro SDK recommends use of 'using' when you work with database objects. It will manage object life cycle.
Try change your code like this:
 using (var feat = featCursor.Current)
                        feat.Store();
GKmieliauskas
Hi Sai,
                        feat.Store();
New Contributor III
Thanks for spotting the issue @Gintautas_Kmieliauskas. I missed that.
I changed the code to a using block and it worked.
Cheers!
