Optimum/best way to extract column data into a list?
593
02-05-2020 12:33 PM
GyanendraGurung
New Contributor III
Hi everyone,
I want to extract all the rows of a specific field in a given table. This is how I am doing it.
  1. List<UInt32> outputList= new List<UInt32>();
  2.
  3. // Query table
  4. await QueuedTask.Run(() => {
  5.     using (Geodatabase curGDB = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(selectedGDB))))
  6.     using (Table table = curGDB.OpenDataset<Table>(selectedTable))
  7.     {
  8.         QueryFilter qF = new QueryFilter
  9.         {
  10.             WhereClause = "OBJECTID > 0"
  11.         };
  12.         using (RowCursor rc = table.Search(qF, false))
  13.         {
  14.             while (rc.MoveNext())
  15.             {
  16.                 using (Row row = rc.Current)
  17.                 {
  18.                     outputList.Add(Convert.ToUInt32(row[selectedField]));
  19.                 }
  20.             }
  21.         }
  22.     }
  23. });
My questions is: Is this a good way? Do I have to use "QueryFilter" and move through each row? Is there a better/optimum way?
Many thanks in advance.
RichRuh
Yes, this is the best way.  I would recommend the following small changes.
  • Remove the WhereClause (which isn't really doing anything, since ObjectIDs should always be greater than zero)
  • Use the Subfields property to reduce the amount of data being read from the database
  • On the call to Table.Search, set the useRecyclingCursor property to True
--Rich
GyanendraGurung
New Contributor III
Hi Rich,
Thank you very much for your kind and prompt reply. I will try to use the Subfields property and optimize my code. I shall post it as soon as I get time to code it.
- Kenny
