MultiThreading / Parallel Processing in ArcGIS Pro AddIn
542
11-04-2019 08:14 AM
GovindaGross
I am working on an ArcGIS 2.4.1 Pro AddIn that processes CPU-intensive tasks. One of the tasks is to create Polygons from parts of different PolyLines, which I achieved with the following code (shortened to the minimal relevant part):
PolylineBuilder polylineBuilder = new PolylineBuilder(SpatialReference);
polylineBuilder.AddParts(contourPolyLine.Parts);
polylineBuilder.SplitAtDistance(splitDistance, falsetrue);
var newPolygon3D = PolygonBuilder.CreatePolygon(polylineBuilder.ToGeometry()
                     .Copy3DCoordinatesToList(), SpatialReference);
This works just fine by itself, but took 40 minutes to process for about 3.000 objects. As this is run within QueuedTask.Run(async () =>...), ArcGIS Pro only utilized 1 CPU core of my 8 core machine. All attempts of separating the work and running several parallel tasks failed so far, because PolylineBuilder can not be used in a regular Task.Run(...)-Thread (Exception is thrown: "This object must be created within the lambda passed to QueuedTask.Run, or on a compatible STA thread.").
I had a look at ProConcepts Framework · Esri/arcgis-pro-sdk Wiki · GitHub  and searched the community samples but couldn't find a similar scenario.
In another ArcGIS AddIn I was able to use 100% of the CPU by creating multiple threads that each take a part of the workload, but in that case I had only calculations with regular managed code and no ArcGIS Pro Tools were involved:
await Task.WhenAll(Enumerable.Range(1, Environment.ProcessorCount).Select(c => Task.Run( () => { DoWork(); }
Is there a solution to utilize the full CPU also for jobs that use ArcGIS.Core.Geometry Tools/Classes like PolylineBuilder?
Any hint or example would be appreciated.
Cheers
UmaHarano
To use the STA thread, you can use the StartSTATask method in the attached TaskUtils.cs file. Here is the usage for the method:
await TaskUtils.StartSTATask<int>(() => {
//Do Polygonbuilder task here.
Reply
