Missing default cancel button on OK only ArcGIS.Desktop.Framework.Dialogs.MessageBox
1456
03-10-2021 01:14 PM
Justin_ODell
Similar to https://community.esri.com/t5/arcgis-pro-sdk-questions/messagebox/m-p/826655,  minor question about ArcGIS.Desktop.Framework.Dialogs.MessageBox vs. System.Windows.MessageBox :
On the System.Windows.MessageBox the MessageBoxButton.OK option allows the Esc key to Cancel/Close the messagebox.
On the ArcGIS.Desktop.Framework.Dialogs.MessageBox the MessageBoxButton.OK option doesn't do anything when the Esc key is pressed.
Was this accidental (a bug) or intentional?
Just curious. Thanks much!
Running in Pro 2.2.0.4
UmaHarano
Hi Justin,
This is a bug, and has been reported to the development team. Thanks for reporting this.
Uma
UmaHarano
Hi Justin,
Uma
Justin_ODell
Uma,
Thanks for confirming!
- Justin
ghefarm
The defaultMessageResult didn't worked for me. It is always OK!
I tried it with both Cancel and None:
Arc.MessageBox.Show("msg", "Title",MessageBoxButton.OK, someIcon, MessageBoxResult.Cancel/None)
Is this the same bug?
Running Pro 2.7.2
UmaHarano
You have to display the cancel button in order to get the Cancel result.
var results = MessageBox.Show("msg", "Title",
                                    System.Windows.MessageBoxButton.OKCancel,
                                    System.Windows.MessageBoxImage.Information)
