Migrating from 2.9 to 3.0: FeatueLayer.RemoveAllDefinitionFilters() replaced by FeatureLayer.RemoveAllDefinitionQueries()?
1086
07-05-2022 10:46 AM
Amadeus111
I am updating my AddIns and switching to SDK 3.0/.Net 6
FeatueLayer.RemoveAllDefinitionFilters() is not resolved the closest function I found is FeatureLayer.RemoveAllDefinitionQueries().  The same issue exists also with FeatureLayer.DefinitionFilter but there is FeatureLayer.DefinitionQuery. I still have many errors I can't run my AddIn. Is there anyone who knows my assumption is right?
https://pro.arcgis.com/en/pro-app/latest/sdk/api-reference/topic11585.html
2 Solutions
CharlesMacleod
that is correct. RemoveAllDefinitionQueries() will do the same thing
UmaHarano
At 3.0, BasicFeatureLayer definition queries have changed.  The ProConcepts: 3.0 Migration Guide covers this topic.  There are also various code snippets that can help you in this wiki.
 var us_states = MapView.Active.Map.GetLayersAsFlattenedList()
                     .OfType<FeatureLayer>().First(lyr => lyr.Name == "US States");
 QueuedTask.Run(() => {
    us_states.SetDefinitionQuery("STATE_NAME = 'Iowa'");
    //equivalent to...
    var def_query = new DefinitionQuery() {
      Name = "A Name that is Unique",
      WhereClause = "STATE_NAME = 'Iowa'"
   us_states.InsertDefinitionQuery(def_query, true);
   var active_def_query = us_states.ActiveDefinitionQuery;
   string where_clause = us_states.DefinitionQuery;//just the where clause string
  //remove the active query
  us_states.RemoveActiveDefinitionQuery();
  //remove using name
  us_states.RemoveDefinitionQueries(new List<string> { def_query.Name });
  //use LINQ to get just a specific query
  var def_query = us_states.DefinitionQueries.FirstOrDefault(
                                         dq => dq.Name == "Query def name");
CharlesMacleod
UmaHarano
    //equivalent to...
  //remove using name
