MapTool.UpdateOverlay - No Overload with referenceScale parameter
1600
6
04-18-2021 12:30 PM
ChristianSchneider1
New Contributor II
I have written a custom maptool where I use overlays to show graphic information on a map view.
In the OnToolActivateAsync I call the AddOverlay method to add the graphic overlay and in my OnToolMouseMove I call the UpdateOverlay method. To this point, everything worked fine.
But know I had the requirement that the overlay symbol should scale according to some reference scale.
In the API there is a overload for the AddOverlay method where I can set the reference scale:
https://pro.arcgis.com/en/pro-app/latest/sdk/api-reference/index.html#topic27602.html
But there is no similar overload for the UpdateOverlay method!
The result is now that when the tool is activated, the graphic is scaled accoring to my reference scale but as I move the mouse, the reference scale setting is lost and the overlay graphics becomes bigger.
I helped myself with destroying the overlay with Dispose and calling AddOverlay with the reference scale parameter in the OnToolMouseMove but that causes a slight flickering of my overlay graphic.
Is there a better way to do this?
Why is there no overload for UpdateOverlay with a reference scale parameter?
2 Solutions
NarelleChedzey
Hi Christian,
Unfortunately I don't think there is a better way of accomplishing what you're attempting to do right now.
I'll add an issue to include an overload for UpdateOverlay on the MapTool and the MapView objects to include the reference scale parameter.  These will be in the next release of ArcGIS Pro.  Since 2.8 is very close to being released, these methods will be added at the 2.9 release.
Thanks
Narelle
NarelleChedzey
I wanted to confirm that an UpdateOverlay overload has been added to the MapTool and MapView classes to include a reference scale parameter at ArcGIS Pro 2.9.
Regards
Narelle
NarelleChedzey
Hi Christian,
Thanks
Narelle
ChristianSchneider1
New Contributor II
Thank you very much Narelle!
CharlesMacleod
GraphicsLayer has a reference scale fyi. That is probably the better option.
Set it via the CIM. Something along the lines of.....
var def = graphicsLayer.GetDefinition() as CIMGraphicsLayer;
def.ReferenceScale = 1000.0; //eg 1:1000
graphicsLayer.SetDefinition(def);
ChristianSchneider1
New Contributor II
Hey Charlie,
how do I get a reference to the graphics layer?
In my case I am just using a custom map tool where I call AddOverlay or UpdateOverlay, I did not explicitly add a graphics layer to my map. The map therefore does not contain a graphics layer in the layer enumeration and map.TargetGraphicsLayer is also null.
I guess there is some kind of hidden graphics layer where the graphics are added by the AddOverlay or UpdateOverlay methods but neither on the map nor on the cimmap I can find a possibility to get a reference to the graphics layer.
CharlesMacleod
you would need to explicitly create one (or the user could add one via the UI).
To add a GraphicsLayer to the map, see here:
https://github.com/Esri/arcgis-pro-sdk/wiki/ProSnippets-GraphicsLayers#create-graphicslayer
More details on GraphicsLayer can also be found here:
https://github.com/Esri/arcgis-pro-sdk/wiki/ProConcepts-GraphicsLayers
NarelleChedzey
Regards
Narelle
