Link group popup to custom Property Page in the Application Options
55
11-07-2018 05:30 AM
I am trying to add a popup to my group which links to a custom Property Page in the Application Options. Therefore I am using the ID of the Property Page in the "launcherButtonID"-Attribute of the group, but this does not seem to work.
Here a snippet of my config.daml:
<propertySheets>
    <updateSheet refID="esri_core_optionsPropertySheet">
      <insertPage id="PropertyPageApplicationSettings"
                  caption="MyAddIn"
                  className="ProApplicationSettingsViewModel"
                  group="Application">
        <content className="SettingsView" />
      </insertPage>
    </updateSheet>
  </propertySheets>
<modules>
     <groups>
        <group id="MyCustomGroup"
               caption="MyGroup"
               appearsOnAddInTab="false"
               keytip="M"
               launcherButtonID="PropertyPageApplicationSettings">
        </group>
      </groups>
Thank you for your help.
Best regards,
Oliver
Reply
Hi Oliver
The launcherButtonID attribute can be set to the ID of a button only. You could create a button that launches your property page in your property sheet. And then you could add this button's ID to the group's launcherButtonID attribute.
I used the SDK PropertySheet template and here is the code snippet for this:
<group id="LaunchPropertyPage_Group1" caption="Group 1"
appearsOnAddInTab="true" launcherButtonID="LaunchPropertySheet_MyNewPropertySheet_ShowPropertySheet">
   <!-- host controls within groups -->
</group>
</groups>
<controls>
     <!-- add your controls here -->
     <button id="LaunchPropertySheet_MyNewPropertySheet_ShowPropertySheet" caption="Show MyNewPropertySheet" className="MyNewPropertyPage_ShowButton" loadOnClick="true" smallImage="Images\GenericButtonPurple16.png" largeImage="Images\GenericButtonPurple32.png">
          <tooltip heading="Show Property Sheet">Show Property Sheet<disabledText /></tooltip>
     </button>
</controls>
</insertModule>
</modules>
<propertySheets>
    <insertSheet id="LaunchPropertySheet_MyNewPropertySheet" caption="MyNewPropertySheet" hasGroups="true">
      <page id="LaunchPropertyPage_MyNewPropertyPage" caption="MyNewPropertyPage" className="MyNewPropertyPageViewModel" group="Group 1">
        <content className="MyNewPropertyPageView" />
      </page>
</propertySheets>
Uma
Reply
Hi Oliver
</group>
</groups>
<controls>
     </button>
</controls>
</insertModule>
</modules>
<propertySheets>
      </page>
</propertySheets>
Uma
Reply
Thank you very much, that solved my problem.
Reply
