Is there a way to create a Definition Query works with Query Filter synchronously in ArcGIS PRO SDK?
156
12-28-2020 11:47 AM
OguzSariyildiz
I have created a table view which users can filter features by making selection via multiple combo boxes
public void UpdateSelection()
    QueuedTask.Run(() =>
        if (_tableContent != null)
            QueryFilter qfFType = new QueryFilter { WhereClause =
             $@"FEATURE_CLASS = '{Feature}'" };
            QueryFilter qfState = new QueryFilter { WhereClause =
            $@"STATE_ALPHA = '{State}'" };
            QueryFilter qfCounty = new QueryFilter { WhereClause =
            $@"COUNTY_NAME = '{County}'" };
            QueryFilter qfQuad = new QueryFilter { WhereClause =
            $@"MAP_NAME = '{Quad}'" };
            Dictionary<QueryFilter, string> FieldFilterDic = new
                        { qfFType, Feature},
                        { qfState, State },
                        { qfCounty, County},
                        { qfQuad, Quad}
            if (Feature == "All")
                FieldFilterDic.Remove(qfFType);
            if (State == "All")
                FieldFilterDic.Remove(qfState);
            if (County == "All")
                FieldFilterDic.Remove(qfCounty);
            if (Quad == "All")
                FieldFilterDic.Remove(qfQuad);
            if (FieldFilterDic.Count > 0)
                var firstFilter = FieldFilterDic.Keys.First();
                var firststring = FieldFilterDic[firstFilter];
                GNISFLayer.Select(firstFilter,
                    SelectionCombinationMethod.New);
                FieldFilterDic.Remove(firstFilter);
                foreach (KeyValuePair<QueryFilter, string> kvp in FieldFilterDic)
                    GNISFLayer.Select(kvp.Key,
                         SelectionCombinationMethod.And);
            else
                GNISFLayer.ClearSelection();
The method above works fine for selecting features based on multiple criteria taken from combo boxes.
I would also like to remove features from the display as user filters out the features.
I think I can adapt the syncing myself as far as if I can use multiple criteria on the Definition Query. For instance,  something like
Definition Query = GNISFLayer.SetDefinitionQuery($@"FEATURE_CLASS = '{Feature}' && $@"STATE_ALPHA = '{State}'"");
Reply
OguzSariyildiz
I was able to use multiple criteria when setting definition by using AND instead of &&.
//Make sure to insert spaces before and after " AND "
string dq = $@"FEATURE_CLASS = '{Feature}'" + " AND " + $@"STATE_ALPHA = '{State}'"
GNISFLayer.SetDefinitionQuery(dq)
Then, I came up with this solution:
public Task<Dictionary<QueryFilter, string[]>> UpdateSelection()
            return QueuedTask.Run(() =>
                    string GNISFType = $@"FEATURE_CLASS = '{Feature}'";
                    string GNISState = $@"STATE_ALPHA = '{State}'";
                    string GNISCounty = $@"COUNTY_NAME = '{County}'";
                    string GNISQuad = $@"MAP_NAME = '{Quad}'";
                    string[] GNISFTypeArr = { GNISFType, Feature };
                    string[] GNISStateArr = { GNISState, State };
                    string[] GNISCountyArr = { GNISCounty, County };
                    string[] GNISQuadArr = { GNISQuad, Quad };
                    QueryFilter qfFType = new QueryFilter { WhereClause = GNISFType };
                    QueryFilter qfState = new QueryFilter { WhereClause = GNISState };
                    QueryFilter qfCounty = new QueryFilter { WhereClause = GNISCounty };
                    QueryFilter qfQuad = new QueryFilter { WhereClause = GNISQuad };
                    FieldFilterDic = new Dictionary<QueryFilter, string[]>
                        { qfFType, GNISFTypeArr},
                        { qfState, GNISStateArr},
                        { qfCounty, GNISCountyArr},
                        { qfQuad, GNISQuadArr}
                    if (State == "All")
                    if (Quad == "All")
                        foreach (KeyValuePair<QueryFilter, string[]> kvp in FieldFilterDic)
                            if ( kvp.Key == FieldFilterDic.Keys.First())
                                GNISFLayer.Select(kvp.Key, SelectionCombinationMethod.New);
                            else
                                GNISFLayer.Select(kvp.Key, SelectionCombinationMethod.And);
                    else
                return FieldFilterDic;
        private void DisplaySelBoolChanged()
            if (DisplaySelBool)
                    if (SelectionDict.Count > 0)
                        GNISFLayer.RemoveAllDefinitionFilters();
                        string entireExp = null;
                                if (kvp.Key == SelectionDict.Keys.Last())
                                    entireExp += kvp.Value[0];
                                else
                                    entireExp += kvp.Value[0] + " AND ";
                        MessageBox.Show(entireExp);
                        GNISFLayer.SetDefinitionQuery(entireExp);
                    else
                        DisplaySelBool = false;
            //else
            //    GNISFLayer.RemoveAllDefinitionFilters();
first method (UpdateSelection()) use the dictionary and return it to the main thread and the same dictionary is used for setting up/impementing the Definition Filter in the DisplaySelBoolChanged() method
 private async void FeatureTypeSelectionChanged()
            var resultDic = await UpdateSelection();
            SelectionDict = resultDic;
            DisplaySelBoolChanged();
Reply
OguzSariyildiz
                    if (State == "All")
                    if (Quad == "All")
                            else
                    else
            if (DisplaySelBool)
                                else
                    else
            //else
Reply
