Is there a bug with opening .jpg images in ArcGIS Pro 2.7?
1177
6
02-16-2021 12:35 PM
Amadeus111
Occasional Contributor II
I am developing a module which pulls aerial images into TOC. I don't have any problem with .tif files but .jpgs.
Here is an example of .jpg image file set
I am able to get the image on the map and TOC but then AGP begins hanging forever. I tried it manually I had the same result. I can open the same file in ArcMap without a problem.
Tags (3)
DanPatterson
MVP Esteemed Contributor
the second file has no extension(?) presumably the *.jpg?
... sort of retired...
Amadeus111
Hi @DanPatterson ,
Yes, it is a jpg file. I did not get the screenshot wide enough.
DanPatterson
hence my question about the missing file extension
Amadeus111
That is how Windows Explorer shows the files in Details mode. I have updated the picture.
KenBuja
If you have the "Hide extensions for known file types" option turned on in the File Explorer, it won't show extensions like jpg, but it will show the ones like .jpg.ovr. For example, if I view a few TIF folders in one directory, this is what it looks like with the option on vs off
DanPatterson
 "Hide extensions for known file types"    ---- grief
