Is it possible to add a custom group to an existing tab?
195
11-09-2020 10:36 AM
DerekSalinas
I have created a custom addin that I would like to house in a custom group the "esri_mapping_homeTab" to the right of the "Offline" group.
I know i need to be able to update the "esri_mapping" module, but do I need to have the module added first?
Thanks any help you can provide!
-Derek Salinas
Wolf
by Esri Regular Contributor
If this is what you want to implement:
You can model your add-in's config.daml after this:
<modules>
<insertModule id="GroupInsertTest_Module" className="Module1" autoLoad="false" caption="Module1">
<groups>
<group id="GroupInsertTest_Group1" caption="Group 1" appearsOnAddInTab="true">
<button refID="GroupInsertTest_Button1" size="large" />
<button refID="GroupInsertTest_Button2" size="large" />
</group>
</groups>
<controls>
<!-- add your controls here -->
<button id="GroupInsertTest_Button1" caption="Button 1" className="Button1" loadOnClick="true" smallImage="pack://application:,,,/ArcGIS.Desktop.Resources;component/Images/GenericButtonBlue16.png" largeImage="pack://application:,,,/ArcGIS.Desktop.Resources;component/Images/GenericButtonBlue32.png">
<tooltip heading="Tooltip Heading">Tooltip text<disabledText /></tooltip>
</button>
<button id="GroupInsertTest_Button2" caption="Button 2" className="Button2" loadOnClick="true" smallImage="pack://application:,,,/ArcGIS.Desktop.Resources;component/Images/GenericButtonBlue16.png" largeImage="pack://application:,,,/ArcGIS.Desktop.Resources;component/Images/GenericButtonBlue32.png">
</button>
</controls>
</insertModule>
<!--Modifying Core Map Tab-->
<updateModule refID="esri_mapping">
<tabs>
<updateTab refID="esri_mapping_homeTab" >
<insertGroup refID="GroupInsertTest_Group1" placeWith="esri_mapping_offlineGroup" insert="after" />
</updateTab>
</tabs>
</updateModule>
</modules>
There's also a sample that adds a button to the "esri mapping homeTab"
arcgis-pro-sdk-community-samples/Framework/WorkingWithDAML at master · Esri/arcgis-pro-sdk-community...
