How to zoom to selected feature in ArcGIS Pro SDK Framework
2656
11-23-2020 01:05 PM
Amadeus111
Occasional Contributor II
I am trying to zoom to a selected feature on a feature layer. I have found some answers here but I was not able to adapt any of them into my situation.
Related answers:
https://community.esri.com/t5/arcgis-pro-sdk-questions/arcgis-pro-sdk-select-feature-from-featurelay...
https://community.esri.com/t5/arcgis-runtime-sdk-for-net/arcgis-runtime-sdk-for-net-zoom-to-features...
https://community.esri.com/t5/arcgis-pro-sdk-questions/pro-sdk-how-to-get-features-after-getfeatures...
string selectedCounty = CountiesListBox.SelectedItem.ToString();
QueuedTask.Run(() =>
   FeatureLayer featLayer = countiesLayer as FeatureLayer;
   QueryFilter qf = new QueryFilter { SubFields = "NAME2" };
   qf.WhereClause = selectedCounty;
   featLayer.Select(qf);
   MapView.Active.ZoomToSelected();
I think I have syntax problem somewhere. If I remove qf I am able to select everything.
by Anonymous User
Not applicable
Hi OguzSariyildiz,
 If you surround your code snippet with a try {} catch {} you should see an error message because of your where clause is not a valid where clause.
The where clause string for a QueryFilter has to be specified in sql where clause format:
			string selectedCounty = "San Bernardino";
				var featLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().Where(fl => fl.Name.Contains("Counties")).FirstOrDefault();
					WhereClause = $@"name = '{selectedCounty}'"
by Anonymous User
Not applicable
Hi OguzSariyildiz,
Amadeus111
The idea was zooming to selected feature when user selects it via a listbox. I knew I was doing something wrong with the whereclause so it worked when I changed the code as
   QueryFilter qf = new QueryFilter { WhereClause = $@"myFieldName =
                                    '{selectedCounty}'" };
Thanks @Anonymous User
