How to set the building date of the AddIn ?
900
05-04-2023 06:50 AM
xavierlhomme
Hi
 I use GitLab CI/CD in order to build the product version of an ArcGIS Pro AddIn.
 Is It possible to change de DAML Date automatically in order to set the Date as the builing Date ?
Best Regards
Xavier Lhomme
GIS Architect / ESIRI Expert
xavierlhomme
Thanks
Effectively, a small powershell script could do the job :
$xmlPath = "Config.daml"
$xml = Get-Content -Path $xmlPath
$currentDate = Get-Date -Format "M/d/yyyy h:mm:ss tt"
$xml = $xml -replace '<Date>.*?</Date>', "<Date>$currentDate</Date>"
Set-Content -Path $xmlPath -Value $xml
Xavier Lhomme
GKmieliauskas
I have written small executable which changes date and version of add-in. Argument of executable is project path.  Executable searches catalog for daml file and makes changes. You can set in project settings Pre-build event:
"..\UpdateAddInDate\bin\Release\UpdateAddInDate.exe" $(ProjectPath)
 UpdateAddInDate.exe is my executable. Project of executable is located in the same solution with add-in
xavierlhomme
Thanks
Xavier Lhomme
