How to persist custom information to a project.
1003
06-27-2023 03:24 AM
DirkTillmanns
Hello everyone,
Pro saves template favorites in the project. Since the favorites are tied to a specific map, it is very likely that they will be saved within the "MapProjectItem". I also need to persist combinations of such EditingTemplates. Does anyone have an idea how I can, for example, couple a json as a custom string to a MapProjectItem (or to the map)?  Are there other ways to persist custom information in the project?
Best regards
Dirk
Eloy
 I know it is not a great solution but in every project you have a Home folder. You can write there a json object  in order to persist information regarding the project.
ArcGIS.Desktop.Core.Project.Current.HomeFolderPath
I hope it helps.
GKmieliauskas
Look at the ArcGIS Pro community sample BackStage_PropertyPage.
Add-in module has two overridden methods:  OnReadSettingsAsync and OnWriteSettingsAsync. They could help you to save your info to project and get it back.
DirkTillmanns
but it would be good to have a link to the map. Otherwise I have to do complex administration when the map changes or is even deleted.
Found this, seems to be a solution.
Wolf
by Esri Regular Contributor
You can persist custom project or application settings as shown here:
ProGuide Custom settings · Esri/arcgis-pro-sdk Wiki (github.com)
