How to modify the contents of a tab?
1705
09-26-2016 05:34 AM
KarlHuber
Like it's possible to modify the content of a group I would like to modify the content of a tab using DAML. I tried:
<ArcGIS>
 <module>
    <updateModule refID="ut_desktop_addin">
      <tabs>
        <updateTab refID="ut_desktop_addin_tab">
          <insertGroup refID="ut_jobmanagement_group" />
        </updateTab>
      </tabs>
    </updateModule>
  </modules>
</ArcGIS>
But that does not work. The new group won't show up.
The point is: I do not want to modify an existing Esri tab but I want to add a new group to one tab that comes with another of our AddIns. Is that generally possible? Or can I modify Esri Tabs and Groups only?
UmaHarano
Hi Karl,
At 1.3 you can control the order by which your add-in is loaded by ArcGIS Pro using the "id" attribute of your Add-in (from the config.daml).
For Example:
"Add-In#1" has an id attribute declared in the config.daml as {c1a60c8f-2f6f-4198-a5d6-ea964ebf678c}.
Add-In#2 has an id of {0d9f5aca-097b-4e49-9e44-505a61b99308}.
Snippet from config.daml given below:
<AddInInfo id="{c1a60c8f-2f6f-4198-a5d6-ea964ebf678c}" version="1.0" desktopVersion
and
<AddInInfo id="{0d9f5aca-097b-4e49-9e44-505a61b99308}" version="1.0" desktopVersion
Pro will load Add-In#2 with GUID 0d9f5aca.. first followed by Add-In#1 with GUID c1a60c8f.. (Alphabetically sequenced).
So Add-In# 1 can modify UI elements declared in Add-In#2.
At 1.4, you will be able to control this better with a "Dependency" tag in the config.daml.
Thanks
Uma Harano
ArcGIS Desktop SDK Team
