How to include a .exe file to the ArcGIS Pro .ESRIAddInX file?
301
8
2 weeks ago
LakshmiAlaparthi
I am trying to include a .exe, file(console application) and .config file to the addin.EsriAddInX file using these options below but its not deploying the .exe and .config files. Can some one help me?
BuildAction = Content,
Copy To Output Directory = Copy Always
Lakshmi
3 Solutions
StephenRhea_GISInc
Hey Lakshmi, if you unzip your .EsriAddInX file (or open it with something like 7-Zip), do those files exist in the expected folder?
StephenRhea_GISInc
No, after you compile it, you can change the extension to .zip and view its contents. There's an Install folder in the zip file that should contain the .exe and .config files, or the folders that contain them if you've nested them.
Wolf
by Esri Regular Contributor
I attached a sample project that runs a console app.   This how you set the properties for the exe that has to be included in your esriaddinx file:
The project is for ArcGIS Pro 2.8, but you can change that in the config.daml to an earlier version:
StephenRhea_GISInc
LakshmiAlaparthi
Hi Stephen,
No. you mean after installing the .ESRIAddInX file?
StephenRhea_GISInc
LakshmiAlaparthi
Thank you for responding.. I changed the extension to .zip and extracted and verified the 'install' folder. It did not pickup the consoleapp.exe and consoleapp.exe.config files.
Wolf
Here is a document showing how to add content to an esriaddinx file and then accesses that custom content during runtime.  ProGuide Content and Image Resources · Esri/arcgis-pro-sdk Wiki (github.com) and a similar question was posted here:
Re: Adding Files to esriAddinX - Esri Community
LakshmiAlaparthi
Thank you for the reply.. What should I select for the build action and copy local options.. if the content type is and exe and the config file?
Wolf
LakshmiAlaparthi
Thank you! I was able to deploy the exe and and the .config file!
