How to get the FeatureType of a FeatureClass
1273
06-03-2020 05:40 AM
EvaSchuh
I am trying to programmatically get the FeatureType of a FeatureClass with the ArcGIS Pro SDK.
More precisely I would like to find out if the FeatureClass is of type Annotation.
I already tried opening the definition of type AnnotationFeatureClassDefinition.
This does not work (returns null):
Geodatabase.GetDefinition<AnnotationFeatureClassDefinition>("myAnnotation")
I can get the FeatureClassDefinition:
Geodatabase.GetDefinition<FeatureClassDefinition>("myAnnotation")
But how do I get the FeatureType?
I am using ArcGIS.Core/ArcGIS.CoreHost in a standalone application.
Does anybody know how to do this?
RichRuh
If you're starting from a FeatureClass object, just try to cast it to an AnnotationFeatureClass:
FeatureClasss myFeatureClass;
if (myFeatureClass is AnnotationFeatureClass)
  AnnotationFeatureClass myAnnotationFeatureClass = myFeatureClass as AnnotationFeatureClass;
Is this what you are looking for?
--Rich
EvaSchuh
Thanks, Rich. I was testing with Annotation-FeatureClasses created with ArcGIS Desktop 10.5.
I now have an Annotation-Featureclass created with ArcGIS Pro and I can either get the AnnotationClassDefinition directly or cast FeatureClass into AnnotationFeatureClass.
RalfSchmidt
Hi Rich,
I just ran into this thread with a similar question. Your answer is valid for the OP's question but in my case I need to get the names of all annotation feature classes in the GDB. Here, your approach would mean that I have to hydrate each FeatureClass only to find out if it is an AnnotationFeatureClass or not.
As there are no alternatives, I will go for that.
However, maybe you guys can add an "IsAnnotationFeatureClass" property to the FeatureClassDefinition object, or – even better – make   Geodatabase.GetDefinition<AnnotationFeatureClassDefinition>("myAnnotation")   and   Geodatabase.GetDefinitions<AnnotationFeatureClassDefinition>()   work.
