How to get information from configuration in AddIn
325
11-18-2020 05:10 PM
yuliu2
Here is the thing:
I have a ProConfiguration program to design startPage and control the AddIns. In ProConfiguration,I set a LogIn page.How can I get the UserName from ProConfiguration in my AddIn program? I need set different functions based on UserName.
The Code in Configuration is simple so I don not copy to this problem.
Thank you
Jerry
Wolf
by Esri Regular Contributor
You can create a class library with your common code, in this case mainly this interface:
public interface IFromConfiguration
	string UserName { get; set; }
Include a reference to this library in both the configuration and the add-in.  In the configuration you need to implement the interface in your Module class (which in my case is called  ConfigurationModule):
internal class ConfigurationModule : Module, IFromConfiguration
	/// ... existing Module code ....
	internal string UserName { get; set; }
	string IFromConfiguration.UserName { get => UserName; set { UserName = value; } }
In your add-in you can now access the configuration as follows - this is from a button OnClick method:
try
	// get the configuration module:
	var configModule = FrameworkApplication.FindModule("ProConfigurationTest_Module");
	if (configModule is ProConfigurationTest.IFromConfiguration configInterface)
		MessageBox.Show($@"Username from configuration: {configInterface.UserName}");
catch (Exception ex)
	MessageBox.Show($@"Error: {ex}");
