How to get Folder ID from portal In ArcGis Pro SKD?
1120
10-17-2017 11:26 AM
HoriaTudosie
Using the ArcGIS Pro 2.0(1) how can I check if  a specific folder in my content exists, create it if not, and obtain its ID.
During publishing a Web Layer, I need as an optional parameter the FolderID - not the name!
new EsriHttpClient().Upload(portal.PortalUri.ToString(), layerItem, "my Layer Name", new[] {"myTag"}, "folderID");
CharlesMacleod
At 2.1, call portal.GetUserContentAsync
var owner = portal.GetSignOnUsername();
var userContent = await portal.GetUserContentAsync(owner);
foreach (var pf in userContent.PortalFolders)
    System.Diagnostics.Debug.WriteLine($"{pf.Name},{pf.FolderID}");
At 2.0, you have to execute the rest query directly for user content (via EsriHttpClient). The url would look like this:
var url = $"{portal.PortalUri.AbsoluteUri}/content/users/{owner}";
var response = new EsriHttpClient().Get(url);
var json = await response.Content.ReadAsStringAsync();
The returned json will contain your folders. See Rest API User Content
