How to enable word wrapping for legend labels?
673
11-23-2021 11:47 AM
LesleyBross1
Does anyone have a C# example of enabling word wrapping for legend labels? This setting is accessible on the Legend Arrangement Options in ArcMap but I can't find a way to set it in the API.
NarelleChedzey
Hi Lesley,
There isn't a property for directly setting label wrapping on the legend object.  But you can access the property via the CIM.    Here's an example of how you do it.
  await QueuedTask.Run(() =>
    var layout = LayoutView.Active.Layout;
    var legend = layout.FindElement("Legend") as Legend;
    if (legend == null)
      return;
    // get the CIM definition
    var def = legend.GetDefinition() as CIMLegend;
    // set label wrapping to 1 inch
    var labelWidthInches = 1;
    // CIM stores in points, so convert
    var labelWidthPoints = LinearUnit.Inches.ConvertTo(labelWidthInches, LinearUnit.Points);
    // assigning a non-zero value sets the wrapping
    def.LabelWidth = labelWidthPoints;
    // Zero value turns off description wrapping
    def.DescriptionWidth = 0;
    // update the CIM definition
    legend.SetDefinition(def);
Narelle
NarelleChedzey
Hi Lesley,
    if (legend == null)
      return;
Narelle
LesleyBross1
This works fine. It is quite obscure and I would never have found it on my own. It would be nice if this could be added as a property. Thanks for your help!
