How to check if geometry has been changed during edit session?
926
04-05-2021 01:13 AM
kirken
New Contributor III
Hello!
I'd like to know if feature shape has been modified during edit operation , how can I check that?
Using Events (e.g. EditCompletedEventArgs) I get list of Modified features but I need to know if each of these features have geometry changed or not.
RichRuh
Hi Kirken,
If you fetch the changed rows, you can use Row.HasValueChanged to determine if a field has changed.  You can get the field index of the shape field by getting the feature class definition and then calling featureClassDefinition.FindField(featureClassDefinition.GetShapeField()).
I hope this helps,
--Rich
RichRuh
Hi Kirken,
I hope this helps,
--Rich
kirken
New Contributor III
Thanks! I actually tried that but it does not give correct result when using after EditCompletedEvent
Edit has been completed by that time and changes stored, that's why, I guess. I should try some other event, EditCompletingEvent maybe..
