How to add new coded values to an existing domain
2340
8
10-25-2022 09:35 AM
RejeanLabbe
I would like to add new coded values to an existing domain, but I don't know how to do that.
I tried to add values like that, but it doesn't work.
oDomainsList = oGeodatabase.GetDomains();
foreach (Domain oDomain in oDomainsList)
	if (oDomain != null && oDomain is CodedValueDomain)
		if(oDomain.GetName() == sDomainName)
			(oDomain as CodedValueDomain).GetCodedValuePairs().Add("New value 1", "NV_1");
			break;
I can create an new domain if it doesn't exists like this :
SortedList<object, string> oList = new SortedList<object, string> {{"Copper", "C_1"}, {"Steel", "S_2"}};
oCodedValueDomainDescription = new CodedValueDomainDescription(sName, FieldType.String, oList)
	SplitPolicy = SplitPolicy.Duplicate,
	MergePolicy = MergePolicy.DefaultValue
CodedValueDomainToken codedValueDomainToken = schemaBuilder.Create(oCodedValueDomainDescription);
schemaBuilder.Build();
But the domain is not overwritten if it exists.
I tried to delete the domain, hopping I could create a new with all coded values, but I don't know how to do that.
SchemaBuilder.Delete needs a Description parameter, but it looks like there is no way to get that from an existing domain.
https://pro.arcgis.com/en/pro-app/latest/sdk/api-reference/topic40928.html
Remarks
When deleting domains, a CodedValueDomainDescription must be used to delete a ArcGIS.Core.Data.CodedValueDomain and a RangeDomainDescription must be used to delete a ArcGIS.Core.Data.RangeDomain.
There is no example.
Thanks
GKmieliauskas
You can call the same geoprocessing tools from ArcGIS Pro SDK:
                var parameters = Geoprocessing.MakeValueArray(gdb, domName, code, domDict[code]);
                var gpResult = Geoprocessing.ExecuteToolAsync("management.AddCodedValueToDomain", parameters,
                    null, CancelableProgressor.None, GPExecuteToolFlags.None);
RejeanLabbe
I found that it is possible with Python, but I need to do that with ArcGIS Pro SDK.
for code in domDict:
    arcpy.AddCodedValueToDomain_management(gdb, domName, code, domDict[code])
import arcpy
arcpy.env.workspace =  "C:/data"
arcpy.DeleteCodedValueFromDomain_management("montgomery.gdb", "DistDiam", ["20","24"])
GKmieliauskas
RejeanLabbe
Thank you so much @GKmieliauskas I didn't know that Geoprocessing tool could do the same as Python.
I tried your code and it works!
RejeanLabbe
This is my working code to create or update a domain :
public static void AddCodedValueToDomain(Geodatabase oGeodatabase, string sDomainName, string sKey, string sValue)
	var parameters = Geoprocessing.MakeValueArray(oGeodatabase.GetPath().AbsolutePath, sDomainName, sKey, sValue);
	var gpResult = Geoprocessing.ExecuteToolAsync("management.AddCodedValueToDomain", parameters, null, CancelableProgressor.None, GPExecuteToolFlags.None);
public static void DeleteCodedValueToDomain(Geodatabase oGeodatabase, string sDomainName, string sKey)
	var parameters = Geoprocessing.MakeValueArray(oGeodatabase.GetPath().AbsolutePath, sDomainName, sKey);
	var gpResult = Geoprocessing.ExecuteToolAsync("management.DeleteCodedValueFromDomain", parameters, null, CancelableProgressor.None, GPExecuteToolFlags.None);
public static void CreateOrUpdateDomain(Geodatabase oGeodatabase, string sDomainName, SortedList<object, string> oNewValuesList, FieldType oFieldType = FieldType.String)
	IReadOnlyList<Domain> oDomainsList;
	CodedValueDomainDescription oCodedValueDomainDescription;
	SchemaBuilder schemaBuilder = new SchemaBuilder(oGeodatabase);
	bool bDomainExists = false;
	bool bValueExists;
			if (oDomain.GetName() == sDomainName)
				bDomainExists = true;
				foreach (var oExistingValue in (oDomain as CodedValueDomain).GetCodedValuePairs())
					if (!oNewValuesList.ContainsKey(oExistingValue.Key.ToString()))
						DeleteCodedValueToDomain(oGeodatabase, sDomainName, oExistingValue.Key.ToString());
				foreach (var oNewValue in oNewValuesList)
					bValueExists = false;
						if (oExistingValue.Key.ToString() == oNewValue.Key.ToString())
							bValueExists = true;
							break;
					if (!bValueExists)
						AddCodedValueToDomain(oGeodatabase, sDomainName, oNewValue.Key.ToString(), oNewValue.Value);
				break;
	if (!bDomainExists)
		oCodedValueDomainDescription = new CodedValueDomainDescription(sDomainName, oFieldType, oNewValuesList)
RichRuh
Hi Rejean,
You cannot use the Pro SDK to add new coded values to a domain- Python is the answer for now.
The good news is that we'll be adding this capability in Pro 3.1, targeted for Q1 2023.
--Rich
RejeanLabbe
Thanks Rich. I will try Gintautas solution using Geoprocessing Tool.
Rahul_Chahel
Hi Rich
Is this functionality added to Pro SDK?
-Rahul
Aashis
by Esri Contributor
@Rahul_Chahel, Yes. Since Pro SDK 3.1, the API supports adding values to an existing domain using the SchemaBuilder.Modify method. Please refer to the modifying and renaming domain conceptual document and code snippet.
