How can I make a "Select by location" in PRO SDK
4029
11
02-26-2018 11:22 AM
René_AstadDupont
New Contributor II
I have been searching the samples and the API, but so far I have not been able to find any signs on how to make a "Select by Location" in C# With PRO-SDK.
Anyone out there that can point me in the right direction?
Regards
Tags (1)
GKmieliauskas
Hi Rene,
You can use spatial filter on MCT thread:
// execute the select on the MCT
QueuedTask.Run(() =>
foreach(FeatureLayer pItem in pointLayers)
// define the spatial query filter
var spatialQuery = new SpatialQueryFilter() { FilterGeometry = geometry, SpatialRelationship = SpatialRelationship.Contains };
// gather the selection
var pointSelection = pItem.Select(spatialQuery);
If you want to do selection from the tool then you need to override OnSketchCompleteAsync event
protected override Task<bool> OnSketchCompleteAsync(Geometry geometry)
and add code above inside.
JoshuaO_Neil
New Contributor II
Hello,
I am trying to do a select by location (select the state (California, Florida, etc.) from a states polygon layer that polygon project boundary intersects with, and then zoom the map to that state. Would the code for this be similar to above? I cannot seem to figure out how to do this.
Thank you
by Anonymous User
Not applicable
You can also use GetFeatures to return features, as a dictionary, that intersect a search geometry.
      return QueuedTask.Run(() =>
        //create search polygon at 5 pixels
        var searchPoly = CreateSearchPolygon(geometry as MapPoint, 5);
        //find features under the search geometry
        var searchFeatures = MapView.Active.GetFeatures(searchPoly);
        return true;
JeffBarrette
Here is another example that uses the selection from one feature class to select features in another feature class.
//"SelectByLocation" - Select Counties based on selected State polygon
Layout layout = LayoutView.Active.Layout;
await QueuedTask.Run(() =>
  MapFrame mf = layout.FindElement("Map Frame") as MapFrame;
  Map m = mf.Map;
  //Select a single state polygon
  FeatureLayer fl1 = m.FindLayers("State_Polygons").First() as FeatureLayer;
  QueryFilter queryFilter = new QueryFilter();
  string whereClause = "State_Name = 'Rhode Island'";
  queryFilter.WhereClause = whereClause;
  //Use a cursor to get to a feature's geometry
  using (ArcGIS.Core.Data.RowCursor rowCursor = fl1.Search(queryFilter))
    //Grab the first record (and hopefully only record)
    while (rowCursor.MoveNext())
      //Grab the features geometry
      Feature feature = rowCursor.Current as Feature;
      Geometry geo = feature.GetShape();
      //Set up a spatial query
      { FilterGeometry = geo, SpatialRelationship = SpatialRelationship.Intersects };
      //Reference county layer and apply spatial query
      FeatureLayer fl2 = m.FindLayers("Counties").First() as FeatureLayer;
      fl2.Select(spatialQuery);
JoshuaO_Neil
New Contributor II
Jeff, this worked great to select the county as in your example above! Now that I have the selected county, I just cannot figure out how to zoom the map to the selected county.
I am using this, but it zooms to the entire layer, not just the selected feature within the layer.
var lyrExtent = fl2.QueryExtent();
mf.ZoomTo(lyrExtent);
Thank you so much for your help on this!
JeffBarrette
In the above code you already have the geometry of the selection feature.
So add these two lines to the bottom of the code above.
Envelope env = geo.Extent;
mf.ZoomTo(env);
JoshuaO_Neil
New Contributor II
Hmm, that seems to zoom to the state polygon, not the selected county polygon.
JoshuaO_Neil
New Contributor II
Is it possible to zoom to the selected county polygon, not the state polygon?
Your help is much appreciated!
by Anonymous User
Not applicable
@Joshua -
Could you use either of the following?
ZoomToSelected Method
https://pro.arcgis.com/en/pro-app/sdk/api-reference/index.html#topic12028.html
ZoomToSelectedAsync Method
https://pro.arcgis.com/en/pro-app/sdk/api-reference/index.html#topic12029.html
Good Luck!
+ bill
