Get width of a Dockpane pro sdk
2451
9
07-17-2020 02:28 PM
MarvisKisakye1
I have created help content for input parameters on a dockpane which shows up when the user hovers over the info icon to the left of the input parameter as a tooltip. I would like for the tooltip to show up not on the dockpane but to the right of the dockpane. I figured the best way to achieve this would be to set the HorizontalOffset of the tooltip to the width of the dockpane. To achieve this, I need to know the width of the user's dockpane. I figured it would be best to dynamically retrieve the width of the dockpane and use that as the HorizontalOffset  of the tooltip. So how do I access the width of a dockpane. I checked the 'pane' help but it has no width property. Uma HaranoWolfgang Kaiser
Wolf
by Esri Regular Contributor
Try this - eventually you should change the PaneWidth datatype to double.  Note that the snippet below tracks any changes to the width by using the SizeChanged event, covering the case when the operator resizes the dockpane after its initial display.
private bool _initSizeChange = true;
private double GetWidth()
	if (_initSizeChange) {
		_initSizeChange = false;
		base.Content.SizeChanged += Content_SizeChanged;
	return base.Content.ActualWidth;
private void Content_SizeChanged(object sender, System.Windows.SizeChangedEventArgs e)
	if (e.WidthChanged)
		PaneWidth = GetWidth().ToString();
public string _paneWidth = string.Empty;
public string PaneWidth
	get
		if (string.IsNullOrEmpty (_paneWidth))
			_paneWidth = GetWidth().ToString();
		return _paneWidth;
	set
		SetProperty(ref _paneWidth, value, () => PaneWidth);
by Anonymous User
Not applicable
Hi Marvis Kisakye‌,
For right alignment with offset, I think using HorizontalAlignment = "Right" with margin property for offset will do the job for you.
<Grid  Margin="5,0" ScrollViewer.VerticalScrollBarVisibility="Auto" ScrollViewer.HorizontalScrollBarVisibility="Auto">
        <Grid.RowDefinitions>
            <RowDefinition Height="Auto"/>
            <RowDefinition Height="*"/>
            <RowDefinition Height="40"/>
        </Grid.RowDefinitions>
        <Grid.ColumnDefinitions>
            <ColumnDefinition Width="*" />
        </Grid.ColumnDefinitions>
<Grid Grid.Row="0"  Margin="5" HorizontalAlignment="Right" >
FrameworkElement.Margin Property (System.Windows) | Microsoft Docs
Alignment, Margins, and Padding Overview - WPF | Microsoft Docs
Or you can create the margin property and shift the item based on the size of your control as well.
That could be easier I think.
MarvisKisakye1
Yes. My problem is that I need to know the width of the dockpane so that I can set the margin/horizontal offset value. This way, the tooltip always appears just to the right of the dockpane even if it gets resized by the user.
JohnJones
Wolf
Hi Marvis,
 There is no easy way to do this right now, however, there is a workaround since the 'Content' property is 'protected internal' and hence accessible from any derived class (which includes your dockpane).  To test this i added a button to my test dockpane class (CmdWidthTest) that calls the added 'GetFrameworkElement' function.  Needless to say you can make this a property as well.  To access the width use the 'ActualWidthProperty'.
public System.Windows.FrameworkElement GetFrameworkElement()
	return base.Content;
public ICommand CmdWidthTest
	get
		return new RelayCommand(() =>
			var ui = GetFrameworkElement();
			MessageBox.Show($@"Width: {ui.ActualWidth}");
MarvisKisakye1
Wolfgang Kaiser This works well as a button but how do I set it as a property? I attempted to set it as below:
public string _paneWidth = base.Content.ActualWidth.ToString();
            get { return _paneWidth; }
            set
But I get the error "keyword base is not available in the current context"
Wolf
	if (e.WidthChanged)
	get
		return _paneWidth;
	set
MarvisKisakye1
This works perfectly Wolf. Thank you.
SteveVan_Esch
Maybe something like this. I'm manually positioning the tooltip relative to the view's outermost grid.
<Grid x:Name="mainGrid">
  <Button x:Name="myButton" Content="Test" Width="100" Height="40">
    <Button.ToolTip>
      <ToolTip x:Name="popup1" Placement="Custom">test</ToolTip>
    </Button.ToolTip>
  </Button>‍‍‍‍‍‍‍‍‍‍‍‍
    public Dockpane1View()
      InitializeComponent();
      popup1.CustomPopupPlacementCallback = new CustomPopupPlacementCallback(placePopup);
    public CustomPopupPlacement[] placePopup(Size popupSize, Size targetSize, Point offset)
      double scaleX = 1;
      PresentationSource source = PresentationSource.FromVisual(mainGrid);
      // Get the display scale (e.g. 200%)
      if (source != null)
        scaleX = source.CompositionTarget.TransformToDevice.M11;
      Point newPoint = myButton.TranslatePoint(new Point(0, 0), mainGrid);
      CustomPopupPlacement placement1 =
         new CustomPopupPlacement(new Point(((mainGrid.ActualWidth - newPoint.X) * scaleX) + (5 * scaleX), 0), PopupPrimaryAxis.Vertical);
      CustomPopupPlacement placement2 =
          new CustomPopupPlacement(new Point((newPoint.X * scaleX * -1) - popupSize.Width - (5 * scaleX), 0), PopupPrimaryAxis.Horizontal);
      CustomPopupPlacement[] placements =  new CustomPopupPlacement[] { placement1, placement2 };
      return placements;
MarvisKisakye1
Thanks for the response. I would rather use the MVVM pattern and avoid code behind.
