Force Refresh in MapControl
1138
11-10-2021 07:55 AM
StephenDavis1
Hi...I cannot seem to get the MapControl in the Pro C# API to refresh. After setting the content, if I change the selection on a layer, or add labels, or whatever, the MapControl does not update. As I zoom/pan in it, the changes do not apply. It is not until I rebuild the content and set it on the MapControl (i.e. update the bound property) that the new selection or whatever shows in the MapControl. I cannot find a refresh/redraw on the mapcontrol or on any of the layers. I noticed MapView has something like that, but a MapControl in a pane on the side of the app is not going to be the current view. Is there any way to update the selection in a layer in a mapcontrol and have the UI actually show the changes without rebuilding/reapplying all of the content? Thanks so much!
Tags (3)
by Anonymous User
Not applicable
Hi Stephen, we moved your question here to the Pro SDK questions board.
The MapControl does not have a specific redraw method, and content and drawing is managed by your code.  A couple places to look for more ideas:
This MapControl doc section contains a lot of guidance on usage and ViewContent snippets.
Samples using the Map control can be found at:  OverviewMapControl and MagnifierWindow
