EditOperation's callback is not executed for SDE dataset
924
07-04-2017 12:31 AM
MaxMax2
Occasional Contributor II
I have following code:
var operation = new EditOperation
    Name = "Test edit operation",
    ShowModalMessageAfterFailure = false,
    EditOperationType = EditOperationType.Long,
    CancelMessage = null,
    ProgressMessage = null,
    ShowProgressor = false
operation.Callback(context =>
    // I never get here if fc is a feature class from SDE database
fc);
operation.Execute();‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
If fc is a feature class from SDE database I never fall to callback's body. If feature class is from FGDB all is OK. What am I doing wrong?
I'm taking a feature class from Geodatabase returned by GDBProjectItem.GetDatastore.
JeffMatson
I'm assuming your SDE feature class is listed as "editable" in the List by Editing tab?  Are you hydrating the fc variable from a map layer or from a geodatabase object?
MaxMax2
I've updated my question. I'm taking a feature class from Geodatabase returned by GDBProjectItem.GetDatastore. So this feature class is not added to map and I can't see it on List by Editing tab.
JeffMatson
Sorry, I haven't messed with the Datastore object yet.
This works for an SDE layer that isn't in the map:
Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri(" [full path to connection file] ")));
var fc = geodatabase.OpenDataset<FeatureClass>(" [featureClass name] ") as FeatureClass;
