Edit Operation Fails On Second Use
1084
02-06-2017 07:45 PM
ChristopherStayte
I am trying to take the selection the use has and change a value in the field from 'null' to 1. This seems easy with inspector but I run it once and it works fine. I run it the second time and i get an edit operation has failed. I am unsure why this is happening.
public void Update(int status, Layer featureLayer, string editName)
QueuedTask.Run(async () => {
try
var basicfeaturelayer = _selectedLayer as BasicFeatureLayer;
var selection = basicfeaturelayer.GetSelection();
var oidset = selection.GetObjectIDs();
var insp = new ArcGIS.Desktop.Editing.Attributes.Inspector(true);
insp.Load(basicfeaturelayer, oidset);
insp[InpsectorFieldName] = 1;
await insp.ApplyAsync();
basicfeaturelayer.ClearSelection();
} catch (Exception ex)
MessageBox.Show("Error: " + ex.Message);
Reply
SeanJones
Christopher,
Behind the scenes, Inspector.ApplyAsync creates an edit operation, passes the inspector to the modify method and executes it. Since you clear the selection on the first run the oidset will be empty on the second, causing the edit operation to fail as it doesn't distinguish between an empty recordset and other failures.
To avoid the error you can check the count on the oidset before applying.
Reply
ChristopherStayte
Thanks for the feedback. I check the user selection before each pass. I am using this tool so that a user can click on an item and mark it as "done" or 1. That way they can pan and move on to the next one and select it and mark it as "done". There is a selection on the second time and for some strange reason if I save before I run the method it works the second time. In arcobjects I am able to accomplish this using a cursor. I am wondering if the implementation just isn't there yet on pro.
Reply
SeanJones
The implementation you have should be fine. Here's the code I'm using:
    protected override void OnClick()
        try
          var featLayer = MapView.Active.Map.FindLayers("Ranger stations").First() as BasicFeatureLayer;
          var selection = featLayer.GetSelection();
          var insp = new ArcGIS.Desktop.Editing.Attributes.Inspector();
          insp.Load(featLayer, oidset);
          insp["TEST"] = 1;
          featLayer.ClearSelection();
Working after a save is curious. What's your data source? Shapefiles, filegdb, enterprise, feature service etc?
To date ive just been testing on a filegdb. I can select a point, run the code, select another point etc.
Are these newly created features in your edit session or have previously existed?
Reply
ChrisStayte
New Contributor II
I am editing from a file geodatabase. These are newly created features. I have also tested on existing features.
Here is my view model.
 InspectorSettingsViewModel.cs · GitHub
Reply
Wolf
by Esri Regular Contributor
Hi Christopher,
 I tried this sample from the community samples:
 https://github.com/esri/arcgis-pro-sdk-community-samples/tree/master/Editing/ConstructionTool
and changed the code by commenting out the "Use edit operations ..." region in AttributeButton.cs and instead uncommented the "#if OrUseThis" section following the above region.  I think this closely reflects the workflow you describe above.  I then used the community sample dataset and ran the sample  and was able to execute the update multiple times.  Maybe you can see differences between the sample and your implementation.  Also I used Pro 1.4 for this.
Attribute columns are updated
Reply
